[GRASSLIST:764] Re: GRASS in Iceland-problems with running NVIZ
Mike Thomas mthomas at gil.com.au
Mon Jul 21 06:06:03 EDT 2003
Hi Florent.
I'm a bit confused by your email.  You say you are using Cygwin Grass but
the NVIZ packages you refer to are Linux.
Can you clarify.
I'm replying a little too late, so hopefully you've sorted this out.
Cheers
Mike Thomas.
----- Original Message -----
To: "english mailing list GRASS" <grasslist at baylor.edu>; "NVIZ"
<nvizlist at grass.itc.it>
Sent: Tuesday, July 15, 2003 2:12 AM
Subject: [GRASSLIST:714] GRASS in Iceland-problems with running NVIZ
Hello everybody
I'm using GRASS 5.0.2 with Cygwin and the TCL/TK
interface and I would like to run nviz.
When I first tried to run it an error message said
that the file 'pq.dll' was missing and I was told to
download the Cygwin's postgreSQL package.
I downloaded PostgreSQL 7.3.3 and installed it but the
problem was not solved.
Then I downloaded the file
'nviz_postgresql_tk83_i686-pc-linux-gnu_.tar.gz' and
installed with:
        start grass5
        cd $GISBASE
        tar xvfz
nviz_postgresql_i686-pc-linux-gnu.tar.gz
When I enter 'nviz' at 'GRASS:/ >' there is no message
telling that pq.dll is missing but the following lines
are displayed:
/usr/local/grass5/etc/nviz2.2/NVWISH2.2: 1: Syntax
error: "(" unexpected
child process exited abnormally
    while executing
"/usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
-name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name
NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
NVIZ >&@stdo..."
    (file "/usr/local/grass5/bin/nviz" line 16)
Do you know what the problem is and the possible
solution to solve it?
Thank you very much.
    Florent AUBIN
___________________________________________________________
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Yahoo! Mail : http://fr.mail.yahoo.com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.497 / Virus Database: 296 - Release Date: 2003-07-04
