[GRASSLIST:338] Re: hatching
Miha STAUT mihastaut at hotmail.com
Tue Jun 10 08:06:44 EDT 2003
Radim thanks. Evidently I did not read the ps.map instructions thoroughly
enough.
>On Friday 06 June 2003 00:04, Miha STAUT wrote:
> > Hi everybody,
> > Has anybody of the developers ever thought to add to the d.vect.area and
> > ps.map a hatching facility. I think it is very useful if you can print
>on
> > the screen (and on the printer too) more than just one aerial variable.
>Is
> > this difficult? I know ArcView 3.1 has it but overprints one hatch over
> > another so that the lower layers are not visible.
> > I had experience with 8 layers derived from r.poly which were quite big
> > (between 50000 and 100000 lines). All the CAD programs stucked. Arcview
> > made it in a flash just as probably GRASS would (the same way as colour
> > fills the polygons).
> > Should I add this to the wish list?
> > Can anybody indicate a program where broad and fast hatching facilities
>are
> > available?
>It is possible to hatch areas in ps.map by 'pat' option.
>(usability on usual GRASS level :-)
>http://mpa.itc.it/radim/g50/pattern.png
>Radim
_________________________________________________________________
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
