[GRASSLIST:522] Re: import HDF?
Andrey Kiselev dron at ak4719.spb.edu
Wed Jun 25 06:50:30 EDT 2003
On Wed, Jun 25, 2003 at 01:41:29PM +0900, Alip.Yasin wrote:
> I am just downloaded a file named "V1KRNS10__19980601_NDVI__W-Asia" from the
> "Free Vegetation Products".
> After extract I got files
>     " 0001_LOG.TXT
>        0001_NDV.HDF
>        0001_QL.TIF
>        0001_RIG.TXT
>        0001_SM.HDF "
> For introduce into GRASS, I used "r.in.gdal" to 0001_QL.TIF, but it said
>     "PROJ_INFO & PROJ_UNITS file not found for location 'mylocation' ";
> For "r.in.gdal" to 0001_NDV.HDF file, it said:
>     "0001_NDV.HDF not recognised as a supported file format.
It seems your GDAL library compiled without HDF support.
Does `hdf4' format listed in
$ gdal-config --formats
output? If not you should recompile GDAL with HDF support. Build
instructions for GDAL available here:
 http://www.remotesensing.org/gdal/gdal_building.html
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
