[GRASSLIST:542] Re: i.composite and d.rgb
Glynn Clements glynn.clements at virgin.net
Thu Jun 26 18:57:15 EDT 2003
Daniel Victoria wrote:
> I want to use a color composite in order to select
> signature sites. The thing is, when I create the color
> composite with i.composite the colors comes too dark,
> differente from when I display them with d.rgb. The 3
> images used have a grey.eq color table...
d.rgb uses the map's colour table, i.composite doesn't.
Try using r.rescale.eq to equalise the actual category values rather
than the colour table.
Glynn Clements <glynn.clements at virgin.net>
