[GRASSLIST:5706] v.proj problems - state plane to UTM
Philipp Molzer phil at molzer.net
Sun Mar 2 12:13:23 EST 2003
I'm using grass5.0.0 on Linux RedHat8 (intel).
I have a DEM upon which I'd like to overlay some census data (vectors).
 The DEM is in UTM format while the vectors are in state plane format.
 Both locations are NAD83.  Both cover the area of Essex County, New
Jersey, USA. When I use v.proj to bring the vectors from my state plane
location to my UTM location, the resulting vector data has coordinates
that seem to be incompatible with the DEM coordinates.  The east and
west bounds of the imported vector layer appear to be way off.
Also, I can't figure out how to change locations  except by exiting and
restarting grass.
Here are the details:
Source of DEM
DEM was imported into a location with these specifications
    datum:   nad83
    dx:      0.000000
    dy:      0.000000
    dz:      0.000000
    proj:    utm
    ellps:   grs80
    a:       6378137.0000000000
    es:      0.0066943800
    f:       298.2572221010
    zone:    18
    PROJ_UNITS file:
    unit:    meter
    units:   meters
    meters:  1.0
This is the code I used to do the import.
#the DEM is a set of patched together DEMs which I got from the New
Jersey geol survey, covering Essex county
#the DEMs were in SDTS format
#this script includes extracting the files and importing them, then
patching all together
    cd /DATA/GIS/NJ/ESSEX/DEM
    export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/usr/local/lib:/usr/lib
    LIST=`ls -1 *.GZ`
    L1=`echo $LIST |sed -e "s/\.DEM\.SDTS\.TAR\.GZ//g"`
    for FILE in $L1; do
      mkdir $FILE
      mv ${FILE}* $FILE
      cd $FILE
      tar zxvf ${FILE}.DEM.SDTS.TAR.GZ
      FILE=`ls *CATD*`
      F1=`echo $FILE |awk '{print substr($0,0,4)}'`
      OUT=`echo $DIR |sed -e "s/\///"`
      r.in.gdal -e input=$FILE output=$OUT
      r.support -r map=$OUT
      cd ..
    done
    r.patch
    input=1705847,1705869,1706050,1706056,1706084,1706086,1706096,1706105
    output=essexdem
r.info map=essexdem
         | Layer:    essexdem                       Date: Sun Feb 23
        14:47:27 2003    |
         | Mapset:   essex_utm                      Login of Creator:
        pmolzer         |
        NJ_utm                                                           |
         | DataBase:
        /home/pmolzer/grassdata                                          |
         | Title:     ( essexdem
         |   Type of Map:  raster              Number of Categories:
        80               |
         |   Data Type:
        FCELL                                                      |
         |   Rows:
        25848                                                      |
         |   Columns:
        22425                                                      |
         |   Total Cells:
        579641400                                                  |
         |        Projection: UTM (zone
        18)                                           |
         |            N: 4528864.484212    S: 4503016.5481   Res:
        0.99999753          |
         |            E: 574950.240953    W: 552525.236985   Res:
        1.00000018          |
         |   Range of data:    min =  0.000000 max =
        206.899994                       |
         |   Data
        Source:
         |   Data
        Description:
         |    generated by r.patch
Source of vectors
Vectors were imported into a location with these specifications:
    datum:   nad83
    dx:      0.000000
    dy:      0.000000
    dz:      0.000000
    proj:    tmerc
    a:       0.63782064e+07
    es:      0.6768657997291094e-02
    x_0:     0.6096012192024384e+06
    y_0:     0
    k:       0.999975e+00
    lon_0:   74d40'w
    lat_0:   38d50'n
    PROJ_UNITS file:
    unit:    foot
    units:   feet
    meters:  0.3048000000
Source data was an arc/info vector .shp file downloaded from New Jersey DEP
http://www.state.nj.us/dep/gis/digidownload/zips/trct/esstrct.zip
This is the script I used to do the import:
    BASE=/DATA/GIS/NJ/ESSEX
    SHP=esstrct
    g.region rast=essexdem
    cd ${BASE}/$SHP
    for ATT in AREA PERIMETER SUM_TOTALP ; do
      v.in.shape -o in=${SHP}.shp out=${SHP}_$ATT attribute=$ATT scale=24000
      v.support map=${SHP}_$ATT option=build
    done
v.info esstrct_AREA
     | Layer:    esstrct_AREA                   Date: Sun Feb 16
    22:44:45         |
     | Mapset:   state1
    Organization:                     |
    creator:                  |
     | DataBase:
     | Title:    Vector map: esstrct_AREA (
    esstrct_AREA)                         |
     |   Type of Map:  Vector (level: 2)        Number of Categories:
    1           |
     |                                          Number of lines:
    644         |
     |                                          Number of areas:
    226         |
     |                                          Number of islands:
    2           |
     |   Projection: State Plane (zone
    0)                                         |
     |            N:     756057    S:
    670935                                  |
     |            E:     599476    W:
    526003                                  |
     |   Source
    date:                                                             |
     |   Original scale
    1:24000                                                   |
     |   Map threshold: 0.00000
I then bring the vectors into my UTM project like this
    v.proj input=esstrct_AREA location=NJ_stpln mapset=state1
    output=esstrct_AREA
    v.support esstrct_AREA
which gives me:
v.info esstrct_AREA
     | Layer:    esstrct_AREA                   Date: Mar 2
    3                     |
     | Mapset:   essex_utm
    Organization:                     |
     | Location: NJ_utm                         Name of creator:
    esstrct_AREA     |
     | DataBase:
    esstrct_AREA)                         |
    1           |
     |                                          Number of lines:
    644         |
     |                                          Number of areas:
    226         |
     |                                          Number of islands:
    2           |
    18)                                                |
     |            N:    4527072    S:
    4501059                                  |
     |            E:     101524    W:
    79046                                  |
     |   Source
    date:                                                             |
     |   Original scale
    1:24000                                                   |
     |   Map threshold:
    0.00000                                                   |
    Comments:
     |     /home/pmolzer/grassdata/NJ_utm/essex_utm/dig_cats
The East and West bounds are totally different than for the DEM, which were
N: 4528864.484212    S: 4503016.5481   Res: 0.99999753
E: 574950.240953    W: 552525.236985   Res: 1.00000018
    Thanks,
    Phil
