[GRASSLIST:5798] Trouble with raster maps and colour ranges.
Nicholls, Ian ian.nicholls at det.nsw.edu.au
Tue Mar 18 17:58:44 EST 2003
Hi
  I am using grass5 on a Linux server and I have imported BIL raster
files using r.in.gdal. The raster files have been supplied from a 1
metre dataset of the entire Australian geographic region. The problem I
am having is that the .hdr files for the BIL raster files indicates
different bit depths for different raster images. When I display the
images I get problems as the colour ranges for some tiles are not the
same as for others, hence when using the elevation data I end of with
that appears to be a 1500km long dead straight cliff face of at least
500m height that runs right through the middle of Outback Australia.
What I would like to know is there any way of having the raster images
imported correctly to allow for this disparity in colour depths.?
Thanks in Advance
Ian Nicholls
This message is intended for the addressee named and may contain
privileged information or confidential information or both. If you
are not the intended recipient please delete it and notify the sender.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030319/5357a5fc/attachment.html
