[GRASSLIST:5808] Re: export of raster map and legend
H Bowman hamish_nospam at yahoo.com
Wed Mar 19 20:07:54 EST 2003
> I have combined a raster map and a legend (d.legend) and would like to
> export both in a *.tiff or related format. r.out.tiff does export the
> map only,; how I can export the legend?
For a quick and dirty screen dump to a PNG file, try:
(and click on the window-to-dump with the crosshairs)
- You'll need the ImageMagick programs installed (most systems already do).
- It isn't double buffered so you'll need to make sure that the window
    is on top, and totally on the screen.
- Gives you all colors at the screen bit-rate, even if you don't have
    GD-2.0 installed.
A repost of a slightly-improved-over-last-time PNG driver display-dump
script will follow..
Hamish
