[GRASSLIST:5932] Trouble with v.surf.rst
Kurt Springs ferret_bard at mac.com
Mon Mar 31 17:46:18 EST 2003
Hi All,
I am trying to create a surface map from vector contour lines.  The method
I've been trying is v.surf.rst.
I have v.surf.rst map8_contour.vect elev=elev10.rst, and I get the following
result:
Percent complete: Warning: strip exists with insufficient data
The number of points from vector file is 124803
The number of points outside of region 0
The number of points being used is 124803
Processing all selected output files
will require 64000016 bytes of disk space for temp files
Percent complete: Warning: taking too long to find points for
interpolation--please change the region to area where your points are.
Continuing calculations...
G_ludcmp() failed! n=0
ERROR: Interp_segmets failed
[2]    Exit 1                        v.surf.rst map8_contour.vect
elev=elev10.rst
I used v.patch to create map8_contour.vect from three vector files.  I can
see the lines in the monitor when I run d.vect.
I also tried using v.to.rast then r.surf.contour.  When I ran
r.surf.contour, it stayed at 0% for over an hour before I stopped it.  When
I tried d.rast for the raster file I created with v.to.rast, it painted the
monitor white.  Then when I ran r.support, it said the file was empty.
Can any one see what I am doing wrong?
Kurt
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030331/4f93c90f/attachment.html
