[GRASSLIST:8] d.rgb still crashes...
Jeff D. Hamann jeff_hamann at hamanndonald.com
Mon May 12 18:52:36 EDT 2003
I've just installed the cygwin grass5.0.2 from the download site and tried
to display a composite image using d.rgb and the display window still
crashes when I try to run the command. Since I've never tried to fix someone
else's GRASS code, how should I go about getting this fixed?
Thanks,
Jeff.
