[GRASSLIST:266] Re: How can I change the 16bit TIFF file to 8bit TIFF file?
Alip.Yasin s01k154 at shako.sk.tsukuba.ac.jp
Fri May 30 11:32:14 EDT 2003
Hello, Markus
'file 20020726.tif ' says that:
     <20020726.tif: TIFF iamge data, little-endian>
and 'file 20020726.jpg' says that:
     <20020726.jpg: JPEG image data, JFIF standard 1.01, aspect ratio, 1*1>
Sincerely
Ghalip.Yasin
> Hi, Markus
> Thank you very much for your advise.
> I use photoshop to converted 16bit channel tiff to 8bit channel.
> But the problem is, I am also tried 'r.in.gdal' with the converted 8bit
> channel TIFF and the origin data of JPEG, and there was an error message
> which says to '20020726.tif':
>          < Warning 1: 20020726.tif: wrong data type 1 for "XMLPacket"; tag
> ignored
XMLPacket? This looks very unusual for a TIFF file.
What does file 20020726.tif say? ('file' is a unix command which tells you
about the file type).
Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030531/22d65653/attachment.html
