[GRASSLIST:1750] Re: Newbie - error: d.dmrc doesn't exists
Jakob Lanstorp j at lanstorp.com
Thu Nov 13 07:56:54 EST 2003
> I believe this means that you are using PERMANENT as your working mapset.
>Have you tried starting GRASS in a different mapset in
> the location?
The sample data spearfish and the global dataset only seems to have one mapset
present, i.e. the PERMANENT one ?
Or do I have mistaken some think.
Thanx,
Jakob
On Thursday 13 November 2003 10:49, Roger Bivand wrote:
> On Thu, 13 Nov 2003, Jakob Lanstorp wrote:
> > When running the Display Manager, I get the error:
> > File /home/Grass/Globaldata/global/PERMANENT/ .d.dmrc doesn't exists.
> > I have tried the spearfish and the global dataset from
> > http://grass.itc.it/data.html
> > How can I handle that error and get to view the map.
> > Been looking at: http://grass.itc.it/gdp/grass5tutor/HTML_en/c407.html
> > Thanx,
> > Jakob
