[GRASSLIST:1751] Re: realtime_gps
Thu Nov 13 07:29:21 EST 2003
> As you said I changed -q to -w in your script and now it works
http://bambi.otago.ac.nz/hamish/m.realtime_gps.sh
[turns out Debian's netcat isn't standard, it has a -q timeout flag]
> But I don't know what should  I write in "USER_PROJ" ?
> Would you please explain it for me in simple language?
$USER_PROJ is the projection parameters used by PROJ.4's cs2cs.
(i.e. everything after the +to)
That is the projection parameters for your current location.
You might look at g.projinfo for some ideas.
see:
http://www.remotesensing.org/proj/gen_parms.html
It's probably better to rewrite the script to use 5.3's m.proj2..
Watch this space, more code is on the way ...
Hamish
