[GRASSLIST:1766] Re: Vector networking tutorial
Maliheh malihehs at yahoo.com
Sat Nov 15 06:22:33 EST 2003
--- Markus Neteler <neteler at itc.it> wrote:
> On Wed, Nov 12, 2003 at 04:53:30AM -0800, Maliheh
> wrote:
> > Hello Markus,
> > Sorry about bothering you!
> > But again about tutorial, Usage Examples - basics,
> > Import 3D DXF/DWG vector data and NVIZ vector
> > visualization:
> > I've downloaded the WATRTOWR.DXF but I don't know
> > where I should copy it, because of when I use
> > "v.in.dxf" interactively, it shows this error:
> > cannot open watrtowr.dxf for dxf file
> > and when I use this:
> > v.in.dxf
dxf=/usr/local/src/GIS/grass5.0.2/data/spearfish/root/vector/watrtowr.dxf
> > it shows :
> > CONVERSION OF
> > DIG FILE:   100%
> > Following DXF layers found:
> > and in this time when I use g.list to view vector
> > files  it doesn't show that file :(
> > Would you please tell me what is my wrong?
> You are importing in GRASS 5.0.2 (or whatever).
> To see the file in 5.7, run 'v.convert' to get it
> into the new
> vector format.
> Markus
Thank you for your response,
but when I use this command (v.convert) in shows:
ERROR: Input vector was not found.
I don't know where should I copy the dxf file?
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
