[GRASSLIST:1805] Re: grass build error: compilation error in r.in.gdal
Glynn Clements glynn.clements at virgin.net
Tue Nov 18 12:22:58 EST 2003
Kirk R. Wythers wrote:
> I'm trying to tweak out the last of my build errors on OSX. When I
> 'make' grass I am getting the error:
> GRASS GIS source code compiled.
> Compilation error in module: src/raster/r.in.gdal (ignored)
We need to see the actual error messages from the output from "make".
> However, I'm still not getting a functional a grass build with a
> functional gdal. On the gdal web site I found the following:
> "In order to run GDAL after installing it is necessary for the shared
> library to be findable. This can often be accomplished by setting
> LD_LIBRARY_PATH to include /usr/local/lib."
> Is this the problem?
No.
> I'm not following what is being referred to here...
That comment refers to a problem which may occur when running
r.in.gdal. Your problem is with compiling it.
Glynn Clements <glynn.clements at virgin.net>
