[GRASSLIST:1871] completely confused about reclass
Christopher Fonnesbeck chris at fonnesbeck.org
Mon Nov 24 16:29:38 EST 2003
I am attempting to reclassify a stream network based on stream order,
using v.reclass.pg in GRASS 5.0.2, following the examples set out in
the documentation. I have a streams layer with a unique HUC6 code for
each segment. There is a corresponding table in postgresql that has the
same codes, along with various stream attributes. If I try and
reclassify using, say only large streams, with the following sql code:
select segment_ta,stream_cla from stream_d where stream_cla>3
and the following v.reclass.pg command:
v.reclass.pg -s sql=bigstream.sql input=streams output=bigstreams
type=line
I get the following error:
ERROR: 1706010416A0002000.00=4
        - invalid reclass rule
I don't see any obvious reason for this to fail. I would appreciate
help from anyone who would enlighten me. Hopefully future versions of
GRASS will have a much easier querying tool than this!
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
