[GRASSLIST:1401] Re: import AVHRR.
Andrey Kiselev dron at ak4719.spb.edu
Sat Oct 4 06:19:37 EDT 2003
On Sat, Oct 04, 2003 at 04:54:03PM +0900, Alip.Yasin wrote:
> Thank you too much.
> I tried command r.in.gdal input=A3164585.L4908097 output=name, but it  said:
> ERROR4: 'A3164585.L4908097' not recognised as a supported file format.
Looks like you have outdated GDAL. Please, run `gdalinfo --formats'
command and check whether the output contains a line for
`L1B: NOAA Polar Orbiter Level 1b Data Set'. If so and you still get an
error when reading your dataset, you should report this problem
via Bugzilla
 http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
