[GRASSLIST:1460] Re: GRASS on OSX -
Ian Macmillan ian_macmillan at umail.ucsb.edu
Thu Oct 9 14:23:13 EDT 2003
You have probably already done this, but make sure you are logged in as an
administrator, I remember I had similar problems when I tried to use grass as a
normal osx user.  Good luck
-i
Quoting Hugh Evans <hevans at mac.com>:
> Hi - I'm trying to run Grass GIS 5.0.2. on Mac OS X (from Openosx.com)
> The install went smoothly enough but am unable to get the GUI / Window
> System running. I have installed Apple X11. I am up to date on all
> System SW.
> I am able to get a pallete up called "Wish" - however when I try to get
> load some kind of rastor - I get the message "No graphics monitor has
> been selected for output.
> Please run "d.mon" to select a graphics"
> I run d.mon and list my displays...
> Hit RETURN to return to menu
>  > list -f
> Monitors:
> name            description                    status
> x0              X-windows graphics display     not running
> x1              X-windows graphics display     not running
> x2              X-windows graphics display     not running
> x3              X-windows graphics display     not running
> x4              X-windows graphics display     not running
> x5              X-windows graphics display     not running
> x6              X-windows graphics display     not running
> CELL            Create GRASS Raster File       not running
> HTMLMAP         Create HTML Image Map          not running
> PNG             Create PNG Map                 not running
> hit RETURN ->
> Examples of other errors:
> GRASS 5.0.2 > NavGetReply failed, -128 xterm Xt error: Can't open
> display:
> GRASS 5.0.2 > tcltkgrass & [2] 2774
> GRASS 5.0.2 > xterm Xt error: Can't open display:
> I feel like I am so close to getting going on GRASS - but this Monitor
> thing is totally hosing me.
> Has anyone battled this in OS X? Any advice and guidance would be
> appreciated.
> Regards,
> Hugh Evans
Ian MacMillan
Geological Sciences-UCSB
