[GRASSLIST:1494] Re: Importing rasters without coordinate system
Markus Neteler neteler at itc.it
Tue Oct 14 11:30:01 EDT 2003
On Fri, Oct 10, 2003 at 03:43:41PM +0200, Kris Nackaerts wrote:
> Dear,
> I'm new to GRASS and experimenting. I have a location specified and want
> to import some rasterdata (aerial imagery) that is not referenced yet. I
> have this data in A/I ASCII GRID format. When I try to import it, I
> loose evrything, since it's ll corner coordinates as defined in the
> header are outside the LOCATION - region. Do I specify a dummy location
> and import all files here before registring the images, or is there a
> more elegant solution?
The problem is that unreferenced data are imported with
negative coordinates by r.in.gdal. So try
#-e extends the default location:
r.in.gdal -e in=aaigrid out=yourrastermap
g.region -p rast=yourrastermap
d.mon x0
d.rast yourrastermap
Then you can use i.group, i.target, i.points, i.rectify or
i.ortho.photo to get a referenced/orthorectified aerial image.
Hope this helps,
 Markus
