[GRASSLIST:1607] Re: problem in grass-5.0.3rc3_src
Glynn Clements glynn.clements at virgin.net
Thu Oct 30 05:52:42 EST 2003
temiz wrote:
> I tried to compile grass-5.0.3rc3_src with postgresql support.
> But ./config gave this error message.
> "Unable to locate ODBC includes, sql.h ... no"
> How can I solve the problem in the slackware 9.1 system ?
1. PostgreSQL support doesn't depend upon ODBC; you can use
--without-odbc and still use the *.pg commands.
2. To build the ODBC driver, you need the UnixODBC library, from
www.unixodbc.org. All external dependencies are listed in the
REQUIREMENTS.html file.
Glynn Clements <glynn.clements at virgin.net>
