[GRASSLIST:1141] Re: FIX: gdal/v.in.dgn support with grass 5.0.2
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Sep 8 12:40:36 EDT 2003
On Mon, 8 Sep 2003, Keith J. Forbes wrote:
> Paul: Thanks for the response. Tried what you suggested
> (--with-gdal=/usr/local/bin/gdal-config)
> and
> --snip
> checking if we should build directly against GDAL... yes
> no
> checking whether to use TIFF... yes
> ---snip
> any idea if it will build directly against GDAL (since it said yes, and then
> no???!!!!)
Looks like you found a long-standing bug in the configure script (only
happens when you specify the full path to gdal-config). It said yes to
that and then checked again to see if you had done just --with-gdal, and
the answer to that was no! I have fixed it in CVS so the second check is
conditional on the first one failing. The bug was harmless though.
Paul
