[GRASSLIST:1205] Re: r.mapcalc error
Bill Dickinson Jr wdickins at pop700.gsfc.nasa.gov
Thu Sep 11 14:00:47 EDT 2003
Final note on this error. I recompiled, from source, as Hamish
suggested and r.mapcalc works fine now.
Thanks.
Bill
>Just for everyone's edification, here is where I am at on this error.
>I tracked down one reference to readline errors under OS X -
>	http://www.astro.washington.edu/owen/InstallingPython2.2.1OnJaguar.html
>This document gives instructions for installing readline on 10.2
>with a change in the /support/shobj-conf file. This change is
>recommended because "With 10.2, ncurses stuff was moved from the
>System library to external libraries and the process for dynamic
>libraries changed."
>I downloaded readline 4.3-5, removed readline through my Fink
>installation, and went through the process of installing readline as
>outlined in this document. The install went fine, but the change did
>not fix the error I receive when trying to use r.mapcalc in GRASS
>5.0.2. I still get:
>GRASS 5.0.2 > r.mapcalc
>dyld: r.mapcalc version mismatch for library:
>/usr/local/lib/libreadline.4.dylib (compatibility version of user:
>4.2.0 greater than library's version: 4.0.0)
>Trace/BPT trap
>Reading this, does it mean that GRASS 5.0.2 has something in it that
>is looking for 4.0.0 while my OS X version of readline is actually
>4.2.0 (or is it the other way around)? If so, can someone look into
>fixing this somehow if the fix is worth the time?
>For now, I will take Hamish's suggestion and recompile GRASS 5.0.2
>*without* readline. ;-)
>Thanks.
>Bill
>>  > Anybody run across this error?
>>>  Trace/BPT trap
>>Some hints & guesses:
>>".dylib" means it is a Mac OS/X Dynamic Library & thus a OS/X specific
>>problem. It seems r.mapcalc was compiled with readline 4.2.0 headers
>>while the main system libary for readline on your computer is only 4.0.0.
>>You might have two versions on you computer, but I'd guess you are
>>trying to use binaries compiled on someone elses (more up to date) OS/X
>>system.
>>Binary install:
>>Try updating the system's realine libraries (fink?) to 4.2.0.
>>Source install:
>>Try compiling without the --with-readline ./configure option, it
>>isn't critical, I think.
>>Hamish
>>disclaimer: I have no idea.
>Bill Dickinson
>GIS Specialist
>NASA Goddard Space Flight Center
>Environmental & Safety Branch, Code 250
Bill Dickinson
GIS Specialist
