[GRASSLIST:1216] install GDAL & import Landsat7 ETM+ xxx...xxx...bx0.l1g File (HDF)
Alip.Yasin s01k154 at shako.sk.tsukuba.ac.jp
Fri Sep 12 14:20:13 EDT 2003
Dear Grass Users
Recently, I bought a Landsat7 ETM+ data from Michigan State University,
 which in HDF format:
 ( l71146029_02920010925_b10.l1g, ., l71146029_02920010925_b80.l1g).
And to import this file into GRASS, I learned that I must have GDAL
installed in my PC.
So following to [Building GDAL From Source] instruction, I installed it into
my Linux system.
Following is the directory:
 /usr/local/grass5
 /home/gdal-1.1.9
And the instruction said that:
[In order to run GDAL after installing it is necessary for the shared
library to be findable. This can often be accomplished by setting
LD_LIBRARY_PATH to include /usr/local/lib].
But I don't know how to do this.
Please tell me how I could do this step.
Heartfully thanks to any advice.
Ghalip.Yasin (Alipu.Yasen)
Tsukuba University, Japan
