[GRASSLIST:1225] Re: install GDAL & import Landsat7 ETM+ xxx...xxx...bx0.l1g File (HDF)
Fri Sep 12 23:49:57 EDT 2003
> And the instruction said that:
> [In order to run GDAL after installing it is necessary for the shared
> library to be findable. This can often be accomplished by setting
> LD_LIBRARY_PATH to include /usr/local/lib].
> But I don't know how to do this.
edit /etc/ld.so.conf and add /usr/local/lib to the list if is isn't
there. Then run /sbin/ldconfig.
or maybe LD_LIBRARY_PATH=/usr/local/lib:${LD_LIBRARY_PATH}
Hamish
