[GRASSLIST:1265] Re: readline problem and fix
Jack Varga jvarga at boulder.net
Tue Sep 16 22:20:36 EDT 2003
Glynn,
Thanks for the explanation.  I'm reposting to the list as I'm sure
someone can benefit from this down the road.
Best regards,
Jack Varga
Glynn Clements wrote:
>Jack Varga wrote:
>>>I'd rather they just filed bug reports with their OS vendor until the vendor issues a version of readline with the correct dependency information (as is the case for e.g. RH6.2's readline).
>>Until they do, would it be advantageous to add links for each of these
>>shared libraries?
>We definitely don't want to link in more than one of them; on many
>platforms, that in itself would cause an error. On platforms which
>allow this, only one of them (typically either the first or last)
>would actually be used. Also, if you specify a library which doesn't
>exist, that will usually cause an error even if the library isn't
>actually required.
>>Relatedly, don't termcap and terminfo libraries, for
>>all practical purposes, provide the same functionality?
>They provide the same essential functionality, i.e. they provide
>functions which allow an application to determine whether the current
>terminal type supports a particular feature and, if so, which codes
>are used to activate it. However:
>1. There are two different sets of functions: the original termcap API
>(tgetstr etc) and the newer terminfo API (tigetstr etc).
>2. There are two different database formats: the original termcap
>format (a single text file, typically /etc/termcap) and the newer
>terminfo format (a directory tree of binary files, with one file for
>each terminal type).
>To complicate matters, there is no guarantee that the choice of API
>matches the choice of database; it's quite possible that a library
>provides the termcap API but actually uses the terminfo database (a
>common approach is to try terminfo first then termcap).
>While the configure script can readily determine whether a library
>provides the correct API, there is no practical way for it to
>determine which database is used. Which is unfortunate, because the
>choice of database may be important; it's quite possible that one
>database is more complete and/or more accurate than the other.
>>For that
>>matter, isn't curses decprecated by ncurses (new curses)?
>Yes, although:
>1. We make reasonable efforts to support legacy systems.
>2. Of the libraries in question ([n]curses, termcap, tinfo), [n]curses
>should be the last choice. The other two are much simpler, simply
>providing an interface for querying the termcap/terminfo databases.
>Curses is a higher-level library, and significantly more complex (and
>hence more likely to introduce additional problems) than the other
>two.
>In summary: configure can easily go through a list of combinations,
>such as:
>	-lreadline -ltinfo
>	-lreadline -ltermcap
>	-lreadline -lncurses
>	-lreadline -lcurses
>determining whether each combination succeeds. The problem is that, if
>more than one of the combinations works (and that's highly likely),
>how to choose which combination to actually use. Because it may well
>make a difference.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030916/1443aa4c/attachment.html
