[GRASSLIST:1268] Re: r.in.gdal problem
Massimiliano Cannata massimiliano.cannata at supsi.ch
Wed Sep 17 05:51:22 EDT 2003
I also check that my /etc/ld.so.conf have the /usr/local/lib in and i also run
/sbin/ldconfig but nothing changed.
Do I have to do "make distclean" and then run "./configure --with-gdal
"Cannata, Massimiliano" wrote:
> Hello,
> I've problem running r.in.gdal command, can anyone help
> me?
> this is my comman line:
> GRASS:~ > r.in.gdal input=/home/mcannata/PHL.gif
> output=radar
> Segmentation fault
> GRASS:~ >
> a message in /var/mail/mcannata advice me that:
> GIS ERROR: Unable to initialize GDAL bridge (check libgdal
> installation/LD_LIBRARY_PATH variable)
> I try to reinstall r.in.gdal command:
> [root at maxi r.in.gdal]# gmake5 -i
>    SRC     = /home/mcannata/tmp/grass5.0.2/src
>    CMD     = /home/mcannata/tmp/grass5.0.2/src/CMD
>    UNUSED  = /home/mcannata/tmp/grass5.0.2/unused
>    HEADER  = head.i686-pc-linux-gnu
>    ARCH    = i686-pc-linux-gnu
>    GISBASE =
> /home/mcannata/tmp/grass5.0.2/dist.i686-pc-linux-gnu
>    VERSION = 5.0.2 April 2003
> /home/mcannata/tmp/grass5.0.2/src/raster/r.in.gdal
>    make -f OBJ.i686-pc-linux-gnu/make.rules
> make:
> `/home/mcannata/tmp/grass5.0.2/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal'
> is up to date.
>    make -f OBJ.i686-pc-linux-gnu/make2.rules
> make: `/usr/local//grass5/etc/bin/cmd/r.in.gdal' is up to
> date.
> do I miss something in my configuration? How to check it?
> Thanks a lot.
> Eng. Massimiliano Cannata
> Phd student
> www.supsi.ch
note: change my e-mail reference to massimiliano.cannata at supsi.ch
      because the old one will be deleted soon.
Ing.  Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
