[GRASSLIST:3308] Re: GRASS 5.0.3 problem
Glynn Clements glynn.clements at virgin.net
Fri Apr 30 00:34:58 EDT 2004
Thomas Adams wrote:
> I have been running GRASS 5.0.2 until recently with relatively few
> problems. However, two days ago I decided to upgrade to GRASS 5.0.3 and
> encountered the following problem:
> [oper at dell5-tir data]$ grass5
> Cleaning up temporary files.....
> Starting GRASS ...
> /usr/local/grass5/etc/set_data: /lib/i686/libc.so.6: version `GLIBC_2.3'
> not found (required by /usr/local/grass5/etc/set_data)
> Any thoughts what I can do? I've been trying to build glibc-2.3 but I
> have not succeeded (I can not generate a make file even though the
> 'configure' seems to complete OK).
Building GRASS from source is likely to be simpler (and less risky)
than building (and installing) a newer version of glibc from source.
Glynn Clements <glynn.clements at virgin.net>
