[GRASSLIST:4246] Re: DBMI-Postgres driver error
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Aug 25 08:47:59 EDT 2004
On Tuesday 24 August 2004 08:17, Sabine Grabner wrote:
> hello martin, `trust` is possibly not what you want, as your data are not
> safe in this case. i used `md5`.
well at the moment it is not important that the data is safe - it's just a
trial on my computer.
Despite the change to trust I still get the error messages.
I listed below what I did:
I replaced "ident" in /etc/postgresql/pg_hba.conf to "trust" where localhost:
# TYPE DATABASE USER IP-ADDRESS IP-MASK METHOD
# Database administrative login by UNIX sockets
local all postgres ident
sameuser
# All other connections by UNIX sockets
local all all ident
sameuser
# All IPv4 connections from localhost
host all all 127.0.0.1 255.255.255.255 trust
sameuser
# All IPv6 localhost connections
host all all ::1
ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff trust sameuser
host all all ::ffff:127.0.0.1/128 trust
sameuser
# reject all other connection attempts
host all all 0.0.0.0 0.0.0.0 reject
psql grass_test
create user baliola;
grass_test=# select * from pg_shadow;
usename | usesysid | usecreatedb | usesuper | usecatupd | passwd | valuntil
| useconfig
postgres | 1 | t | t | t | |
baliola | 100 | f | f | f | |
(2 rows)
but when I start grass57 and do:
GRASS 5.7.0:~ > db.connect driver=pg
database="host=127.0.0.1,dbname=grass_test,user=baliola"
driver:pg
database:host=127.0.0.1,dbname=grass_test,user=baliola
db.test test1
create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
DBMI-Postgres driver error:
cannot get user/password
EXECUTE: ******** ERROR ********
0a1,3
> 1|123.456000|abcd|
> 3|0.000000|_\'_|
> 2|18.600000|xxx|987
RESULT: ******** ERROR ********
drop table grass_test1
any idea what I did wrong?
Cheers Martin
> Zitat von Martin Wegmann <wegmann at biozentrum.uni-wuerzburg.de>:
> > On Monday 23 August 2004 16:23, Radim Blazek wrote:
> > > And 'psql -h localhost grass_test'?
> > > Maybe you need to edit pg_hba.conf.
> > psql: FATAL: IDENT authentication failed for user "baliola"
> > the non # part of pg_hba.conf looks like:
> > METHOD # Database administrative login by UNIX sockets
> > sameuser
> > local all all ident
> > sameuser
> > host all all 127.0.0.1 255.255.255.255 ident
> > sameuser
> > host all all ::1
> > ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff ident sameuser
> > host all all ::ffff:127.0.0.1/128 ident
> > sameuser
> > reject
> > I assume I have to change the 3. and 4. connection (localhost) from ident
> > to
> > trust .
> > Martin
> > > Radim
> > > On Monday 23 August 2004 13:54, Martin Wegmann wrote:
> > > > hello Radim,
> > > > On Monday 23 August 2004 12:43, Radim Blazek wrote:
> > > > > GRASS cannot store passwords, if your DB requires a password
> > > > > add it to the database parameter. Try psql first.
> > > > The user is set up as a non-passwd user ('with password' is not used)
> > > > I can enter psql grass_test without being prompted for a password.
> > > > baliola at diomedea:~$ psql grass_test
> > > > Welcome to psql 7.4.3, the PostgreSQL interactive terminal.
> > > > Type: \copyright for distribution terms
> > > > \h for help with SQL commands
> > > > \? for help on internal slash commands
> > > > \g or terminate with semicolon to execute query
> > > > \q to quit
> > > > grass_test=#
> > > > drop user baliola and created a new user with specifying a passwd:
> > > > create user baliola with password 'test';
> > > > however psql is not prompting for as passwd when entering the
> > > > grass_test db.
> > > > exit postgres and superuser -- starting grass57 as baliola
> > > > database="host=localhost,dbname=grass_test,user=baliola,password=test
> > > >" driver:pg
> > > > database:host=localhost,dbname=grass_test,user=baliola,password=test
> > > > db.tables -p
> > > > Cannot connect to Postgres: FATAL: IDENT authentication failed for
> > > > user "baliola"
> > > > I did it as well with ' around the password phrase -- same result.
> > > > Martin
> > > > > Radim
> > > > > On Monday 23 August 2004 11:55, Martin Wegmann wrote:
> > > > > > hello,
> > > > > > I did my first steps with postgresql and grass and ran into some
> > > > > > problems: First I created an user and set up a db ("grass_test")
> > > > > > starting grass (5.7.0):
> > > > > > database="host=localhost,dbname=grass_test,user=baliola"
> > > > > > I am not sure if "host=localhost" is correct. In all documents I
> > read
> > > > > > so far, an IP address was specified but using 127.0.0.1 resulted
> > > > > > in the same error prompt. What do I enter when postgresql is
> > > > > > running locally?
> > > > > > If I proceed and do 'db.test grass_test' then db.test tells me
> > > > > > that the db must exist.
> > > > > > If I do db.test test1 I get:
> > > > > > and various Postgresql commands
> > > > > > Any idea how to solve that?
> > > > > > I am still searching for a tutorial introducing people to the
> > > > > > postgresql inside GRASS usage, so far I found
> > > > > > http://mpa.itc.it/markus/shortcourse/notes6.html and
> > > > > > the GRASS 5.7 usage example document. any links are welcome.
> > > > > > regards, Martin
