[GRASSLIST:5156] Can't find r.in.srtm in GRASS CVS
Eduardo Patto Kanegae lists at webmapit.com.br
Tue Dec 14 10:39:22 EST 2004
Hi  ,
I download GRASS 5.7 CVS 2004-12-13  and built it using:
CFLAGS="-g -Wall" ./configure --prefix=/usr/local/app/grass-cvs-13122004
--exec-prefix=/usr/local/app/grass-cvs-13122004 --enable-shared
--with-cxx --with-mysql --with-mysql-libs=/usr/lib/mysql
--with-mysql-includes=/usr/include/mysql --with-opengl  --with-blas
--with-lapack --with-nls --with-readline-includes=/usr/include
--with-gdal --with-x --without-odbc --without-fftw
--with-proj-libs=/usr/local/lib 2>&1 | tee configure.log
but, after building process, at /grass-cvs-13122004/grass-5.7.cvs/bin ,
I found NO "r.in.srtm"
Is there any special command on "configure" to enable this module?
thanks in advance.
http://www.webmapit.com.br
Treinamento & Consultoria em UMN MapServer e FreeGIS Software
ICQ: 303747254
MSN: eduardo_patto~at~hotmail.com
+55(16)9994-2928
***Fim da Mensagem / End of Message ***
-------- Mensagem Original --------
Assunto: 	[Freegis-list] Re: how to read SRTM files - conclusion!
Data: 	Tue, 14 Dec 2004 10:55:21 +0000
De: 	Eduardo Patto Kanegae <...>
Para: 	freegis-list at intevation.de, gdal-dev at remotesensing.org
Referências: 	<41BDE260.6080600 at webmapit.com.br>
Hi folks,
I'd like to thank everybody for replies contribution... This show us how
powerfull Free Software philosophy can be. 'Cause it's only about
software, it's about to share data and knowledge.
Now, I'm going back to my SRTM task because I have more than one
option/suggestion to do an only job.
Thanks all. I pasted all replies below!
ICQ: 303747254
+55(16)9994-2928
Markus Neteler escreveu:
 Eduardo,
you can use GRASS 5.7-CVS also, I have recently
integrated r.in.srtm.
Markus
Mario Beauchamp escreveu:
On Mon, 13 Dec 2004 18:41:36 +0000, Eduardo Patto Kanegae <lists at webmapit.com.br> wrote:
>I'm downloading SRTM NASA ziped files from
>ftp://e0dps01u.ecs.nasa.gov/srtm/South_America/ but I saw that I don't
>know this file format(.hgt)
You can also get SRTM data in Geotiff format from
ftp://ftp.glcf.umiacs.umd.edu/glcf/SRTM/
And you have the choice between WRS2 and degree tiles.
Mario B.
Landsat images (demo):
http://pages.infinit.net/starged/landsat/home.htm
Eliseo Cantellano escreveu:
 Eduardo.
You can use Global Mapper, also.
Eliseo Cantellano
National University of México
Ethan Alpert escreveu:
Looks like you're grabbing the "unfinished" data.
>From the Documentation directory:
ftp://e0dps01u.ecs.nasa.gov/srtm/Documentation/QuickStart.txt
"Height files have the extension .HGT and are signed two byte integers.
The
bytes are in Motorola "big-endian" order with the most significant byte
first,
directly readable by systems such as Sun SPARC, Silicon Graphics and
Macintosh.
DEC Alpha and most PCs use Intel ("little-endian") order so some
byte-swapping
may be necessary. Heights are in meters referenced to the WGS84 geoid.
Data
voids are assigned the value -32768."
You're going to need to do some processing before you can use these
files.
-e
Ben Discoe escreveu:
Eduardo,
Or, simply drag your .hgt files into some nice GDAL-based software such as
VTP's VTBuilder, which will automatically recognize the .hgt and load it
directly.
-Ben
http://vterrain.org/
Thom DeCarlo escreveu:
Eduardo,
This question has come up quite a few times in several lists I'm on. (I
asked once, myself.)
First, if you are using a Linux computer or can install Cygwin (from
www.cygwin.org) on your Windows computer you can use this bash script that I
modified from Markus Neteler's website:
http://mpa.itc.it/rs/srtm/
This shell program will change the name of the .hgt to .bil. It then
generates the .hdr and .prj files for the ESRI file reader. Finally, it
launches gdal_translate to build a geotiff from the bil file.
HTH,
Thom
Thom DeCarlo
   Do Not Meddle in the Affairs of Dragons
For You are Crunchy and Taste Good with Ketchup
Vincent Schut escreveu:
There has been some postings on this list before about this topic. A google
search on 'gdal srtm' will probably give you these.
Shortly, the hgt files are simple binary data, but can easily be 'translated'
into a BIL file (which can be opened by GDAL) by generating the apporpriate
(text file format) header file. You will find the exact answer on how to do
this in the earlier postings on this list.
Good luck!
Vincent.
>The
>first,
>Macintosh.
>byte-swapping
>Data
>files.
>-e
Eduardo Patto Kanegae escreveu:
> Hi folks,
> runnig "gdalinfo" one .hgt file I only got:
> ERROR 4: `N01W050.hgt' not recognised as a supported file format.
> GDALOpen failed - 4
> Or my GDAL tools is missing something?
> Is there any free software that can read this files?
> thanks
ICQ: 303747254
+55(16)9994-2928
