[GRASSLIST:5202] Re: db.select problem
grit grit.schuster at geographie.uni-freiburg.de
Tue Dec 21 05:41:07 EST 2004
Hello everyone,
thanks very much for your hints.
Installing the CVS solved my problem!
So the queries are working fine now!
Cheers,
Grit
Michael Barton wrote:
>I reported a similar problem from the GUI last week. I understand it was
>subsequently fixed in the CVS.
>Michael
>On 12/16/04 8:03 AM, "grit" <grit.schuster at geographie.uni-freiburg.de>
>wrote:
>>Thanks Stephan!
>>this works fine using the grass prompt:
>>db.select table=corinelandcover sql='select * from corinelandcover
>>where BEREICH_NR=3 and GRUPPE_NR=31 and ART_NR=311'
>>echo "SELECT * FROM corinelandcover WHERE BEREICH_NR=3 AND GRUPPE_NR=31
>>AND ART_NR=311"|db.select
>>But, trying to run the same sql statement through the interactive db.select
>>user interface does end with an error:
>>db.select driver=dbf table=corinelandcover sql=echo"SELECT * FROM
>>corinelandcover WHERE BEREICH_NR=3 AND GRUPPE_NR=31 AND ART_NR=311" fs=||
>>vs=-- nv=NULL
>>Sorry <*> is not a valid option
>>Sorry <FROM> is not a valid option
>>Sorry <corinelandcover> is not a valid option
>>Sorry <WHERE> is not a valid option
>>Sorry, <BEREICH_NR> is not a valid parameter
>>Sorry <AND> is not a valid option
>>Sorry, <GRUPPE_NR> is not a valid parameter
>>Sorry, <ART_NR> is not a valid parameter
>>I tried to use the "input=filename" option with the same statement. But in
>>this case all records
>>of the table are selected.
>>I just don't understand it :-(
>>Grit
>>Stephan Holl wrote:
>>>Hello grit,
>>>On Thu, 16 Dec 2004 14:10:58 +0100 grit
>>><grit.schuster at geographie.uni-freiburg.de> wrote:
>>>>Hello,
>>>>could anybody please give me an idea about what I'm doing wrong?
>>>>I'm running db.select on the grass prompt with
>>>>Running the same sql query on db.select interative the following lines
>>>>are printed:
>>>>db.select driver=dbf table=corinelandcover sql='select * from
>>>>corinelandcover where BEREICH_NR=3 and GRUPPE_NR=31 and ART_NR=311'
>>>>fs=|| vs=-- nv=NULL input=/home/grit/sqlstatement
>>>>Sorry <from> is not a valid option
>>>>Sorry <where> is not a valid option
>>>>Sorry <and> is not a valid option
>>>Have you tried another syntax?
>>>This should do:
>>>Make sure, that the table is existent in your location/mapset/dbf-folder
>>>Cheers
>>>Stephan
>____________________
>C. Michael Barton, Professor of Anthropology
>School of Human Evolution and Social Change
>PO Box 872402
>Arizona State University
>Tempe, AZ  85287-2402
>USA
>Phone: 480-965-6262
>Fax: 480-965-7671
>www: <www.public.asu.edu/~cmbarton>
