[GRASSLIST:5222] Re: v.in.ogr advice needed
Kirk R. Wythers kwythers at umn.edu
Wed Dec 22 18:56:29 EST 2004
On Dec 22, 2004, at 5:27 PM, Brent Wood wrote:
> On Wed, 22 Dec 2004, Kirk R. Wythers wrote:
>> I have some shape files that I want to import into 57 and need some
>> v.in.ogr usage advice. The structure of the directory with the shape
>> files is thus:
>> So I tried importing into a new location thus:
> I got the same error message when importing some lat/long shapefiles
> despite the shapefiles lying within the GRASS region & the GRASS
> location
> being lat/long.
> I used the -o flag (via the gui) and it worked fine. I overlaid the
> GRASS
> version of the data with the original shapefile in QGIS & they overlaid
> fine, so I'm assuming the error message about projection mismatches is
> not
> always correct (at least in this case).
> I'm not sure why QGIS can plot a GRASS vector map in half the time
> GRASS
> takes, but they both have their uses :-)
> If you believe you have set up your GRASS location with the correct
> projection details, it could be worth seeing if -o works for you as
> well.
I tried the -o flag before posting. It yielded the same error. While I
didn't to the digitizing myself, the vectors were created from rasters
in the same location that I am trying to import into, therefore the
location and projection should be fine.
Kirk
>    Brent Wood
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
