[GRASSLIST:5233] Re: USGSDEM export
Miha Staut mihastaut at yahoo.co.uk
Tue Dec 28 04:04:18 EST 2004
 --- Tom Russo <russo at bogodyn.org> wrote:
> On Mon, Dec 27, 2004 at 02:36:00PM +0000, we
> recorded a bogon-computron collision of the
> <mihastaut at yahoo.co.uk> flavor, containing:
> > Hi!
> > Any way to output a raster file in a USGSDEM
> format
> > from GRASS?. If I write
> > r.out.gdal in=mydem format=USGSDEM out=mydem.dem
> > the command returns:
> > Error: value <USGSDEM> out of range for parameter
> > <format>
> >        Legal range:
AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,NITF,PAux,PNG,PNM,VRT,XPM
> > Listing all the available formats r.out.gdal
> > understands among other returns USGSDEM
> > r.out.gdal -l
> > USGSDEM: USGS Optional ASCII DEM (and CDED)
> > GRASS 5.7 compiled from cvs (4. 12. 2004),
> gdal-1.2.3.
> > Would a newer version of any solve the problem?
> I'm not exactly sure what the limitation is, but
> I've noticed that gdal
> only partitially supports output of USGSDEM format.
> For example, when I
> try to use the GDAL tool "gdalwarp" to convert a
> USGSDEM from NAD27 datum
> to NAD83 datum, it tells me that the USGSDEM driver
> does not support direct
> creation.  However, if I gdalwarp from the source
> DEM in NAD27 to an
> intermediate GeoTIFF in NAD83, then use
> gdal_translate to create a DEM
> from the GeoTIFF, it does work.
> So my guess is that if you really need USGSDEM
> output you could probably
> do it by outputting to GeoTIFF and then using
> gdal_translate (not a
> GRASS tool, it comes with the gdal library):
>   gdal_translate -of USGSDEM intermediate.tiff
> Final.DEM
> HTH,
> T.
Thanks Tom,
My only scruple is GeoTIFF would destroy the
information. Could that be true?
Miha Staut
___________________________________________________________
ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
