[GRASSLIST:2502] Re: Readline
Glynn Clements glynn.clements at virgin.net
Fri Feb 6 16:35:16 EST 2004
Daniel Victoria wrote:
> Some time ago there was a tread discussing a
> libreadline problem. I'm experiencing the same thin,
> when I run configure on the 5.3cvs I get the error
> unable to locate Readline library
> The configure script finds all readline includes but
> not the library
> I know that the lib is in
> /usr/local/lib/libreadline.so
> On the tread there was a discussion about static or
> dinamyc libraries, but I don't understand that very
> well. Also, there mentioined the command:
> ldd libreadline.so
> which give me
> libgcc_s.so.1 => /usr/local/lib/libgcc_s.so.1
> libc.so.6 => /lib
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2
> What am I doing wrong here?
Trying to use a broken readline library.
Just don't use the --with-readline switch.
Glynn Clements <glynn.clements at virgin.net>
