[GRASSLIST:2514] Re: Interpolate from database
Glynn Clements glynn.clements at virgin.net
Sat Feb 7 16:07:39 EST 2004
Hamish wrote:
> You can use 5.0, but I suggest using 5.3+, so that you can compile
> r.series which lets you do stats on the year's worth of resultant maps
> (after increasing r.series' MAXFILES to something bigger than 365!).
That should say "after increasing libgis' MAXFILES". Specifically, the
macro in question is defined in src/libes/gis/G.h.
Glynn Clements <glynn.clements at virgin.net>
