[GRASSLIST:2547] Re: Xlib - no protocol specified error
Glynn Clements glynn.clements at virgin.net
Tue Feb 10 15:18:37 EST 2004
francesco pirotti wrote:
> Hello, strange error this time.
> I start grass 5.7 and everything is fine.  If I type d.m to start a new
> display manager from the terminal it gives me the following error
> message:
> Xlib: connection to ":0.0" refused by server
> Xlib: No protocol specified
This is an X authentication error. This indicates that
$HOME/.Xauthority (or the file referenced by $XAUTHORITY, if that is
set) is, in some sense, invalid.
One common reason for this is if $HOME isn't set correctly. Try
running "xauth list" to view the list of authentication credentials
which are available to Xlib.
Glynn Clements <glynn.clements at virgin.net>
