[GRASSLIST:2695] Re: stitching geotiffs
Martin du Saire mdusaire at umn.edu
Fri Feb 20 10:04:01 EST 2004
At 04:01 PM 2/19/2004 -0700, you wrote:
>Martin du Saire wrote:
>>Hi,
>>I am a newbie to GRASS (XT, Cygwin/XFree86; GRASS5.0) and GIS trying to
>>stitch together a set of NLCD Geo-Tiff  (USGS Landsat-5, etc.) data files
>>for a set of contiguous states in the US.  I finally figured out how to
>>import them using r.in.gdal -o.  (If there is some inherent problem with
>>overriding the projection checking, please let me know.)
>If you are importing an image in UTM Zone X into a location defined as UTM
>Zone X, then you are doing the correct thing by using -o. (You should not
>use -o to import Zone X into a location of Zone Y). You may also want to
>use -e, which extends the location if needed.
So I can import a Zone X map into a Zone Y location?  Is this any
better/worse than using r.proj?  The bulk of my area of interest is in a
single UTM zone (Zone Y), so maybe the distortions generated by importing
Zone X and Zone Z maps into a location of Zone Y will be small??
>>For starters, how do I go about importing the individual files with their
>>corresponding UTM zone designations into the same project?
>Do I understand correctly that you have images in Zone X, Y Z ... and want
>to have them all in a single projection? If I understand correctly, then
>you need to use r.proj to reproject from the individual zones into the
>single target projection. But maybe I do not understand you goal.
Yes, that is what I am attempting to do. I am stitching together maps for
MN, IA (Zone 15), WI (Zone 16), and ND, SD (Zone 14).  About 80% of my area
of interest is in Zone 15.
I also came across a thread from Feb97 that suggested making symbolic links
of mapsets and then running  g.mapsets.  What you suggest sound more
straightforward.  Would these procedures be equivalent?
>>Assuming I can figure that out, do I use r.mask to remove the background
>>from each of these maps?
>You probably do not need to mask. I am guessing that the background is NULLs?
The background is set to "0". Would a NULL be transparent? Maybe use:
r.null map="name" setnull=0
>Richard Greenwood
>www.greenwoodmap.com
Thanks for your help.
Martin
