[GRASSLIST:2746] Re: Problem importing arc info file
Leonardo Lami leo.lami at katamail.com
Wed Feb 25 11:22:05 EST 2004
I have already made it but the problem is the follow:
>Leonardo Lami wrote:
> I'm trying to import a arc info file with r.in.gdal, because it is not
> supported by r.in.arc (it has not the header section).
> The command seems work well but when I display the raster only a little part
> is right and the rest of the cells of the raster have the value of the
> category set to 0.
> Can someone help me?
> Thank you
> Leonardo
> > I added the header at the beginning of w001001.adf file in this way:
> Hi Leonardo:
> You seem to be be importing and ARC/INFO binary grid with r.in.arc
> which is a tool to import ARC/INFO ASCII grids, so AFAICT it won't work.
> It seems that ARC/INFO binary grid is supported with GDAL [1], so
> maybe you should consider using r.in.gdal.
> HTH
> Gonzalo
> [1] http://www.remotesensing.org/gdal/frmt_various.html#AIG
