[GRASSLIST:2762] Re: Reclassify with r.stats and awk - solution
Christof Bigler christof.bigler at colorado.edu
Thu Feb 26 13:47:14 EST 2004
To get a list such as below, you can use:
r.stats -l in=rt.rmris.ct.r | awk '{printf "%d=%s\n", $1, $2}'
r.stats:  100%
19564=TSF
19578=TSF
19642=GRA
19657=TSF
19680=GRA
19719=TSF
19736=TSF
19738=TAA
But if you want to reclassify your raster map, you need something like:
r.stats -l in=rt.rmris.ct.r | cut -d" " -f2 | sort | uniq | awk '{print
$1,NR}' > tmp
cat tmp
GRA 1
NRK 2
SHR 3
SWI 4
TAA 5
TLP 6
TSF 7
WLK 8
WRE 9
no 10
r.stats -l in=rt.rmris.ct.r | awk 'BEGIN{while((getline line < "tmp") >
0){split(line,A," ");R[A[1]]=A[2] }}{print $1,"=",R[$2],$2}'
r.stats:  100%
19564 = 7 TSF
19578 = 7 TSF
19642 = 1 GRA
19657 = 7 TSF
19680 = 1 GRA
19719 = 7 TSF
19736 = 7 TSF
19738 = 5 TAA
The entire command for the reclassification would then be:
0){split(line,A," ");R[A[1]]=A[2] }}{print $1,"=",R[$2],$2}' |
r.reclass in=rt.rmris.ct.r out=rt.rmris.ct.tmp.r
Thanks to P. from Soil & Water Lab.!
Christof
From: Christof Bigler <christof.bigler at colorado.edu>
Date: 25. Februar 2004 19:19:13 GMT-07:00
To: Grasslist <GRASSLIST at baylor.edu>
Subject: [GRASSLIST:2754] Reclassify with r.stats and awk
> I tried to reclassify a grid map. However, instead of getting the
> category labels, I get zeros. You see the problem here:
> GRASS 5.0.2 > r.stats -l in=rt.rmris.ct.r
> r.stats:  100%
> 19564 TSF
> 19578 TSF
> 19642 GRA
> 19657 TSF
> 19680 GRA
> 19719 TSF
> 19736 TSF
> 19738 TAA
> That's what I expect to get.
> GRASS 5.0.2 > r.stats -l in=rt.rmris.ct.r | awk '{printf "%d=%d\n",
> $1, $2}'
> r.stats:  100%
> 19564=0
> 19578=0
> 19642=0
> 19657=0
> 19680=0
> 19719=0
> 19736=0
> 19738=0
> Why is the second column replaced by zeros? Do I need first to replace
> the category labels with e.g. integer values?
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040226/f232df28/attachment.bin
