[GRASSLIST:2783] continued problems with v.net.alloc
Christopher Fonnesbeck chris at fonnesbeck.org
Sat Feb 28 12:53:45 EST 2004
I am trying to extract a continuous stream layer from a fragmented
layer using v.net.alloc and v.extract, following the 5.7 tutorial, but
have yet to replicate the results properly. I have  a vector layer
derived from a terraflow accumulation raster. In trying to extract the
largest contiguous network, I digitized a point "outlet" near the
outlet of the watershed, then derived a vector to connect the point to
the network using v.distance. The stream layer, outlet point and
connecting vector were the joined using v.patch:
v.patch input=streams_clean,outlet_to_streams,outlet out=streams_outlet
I then ran v.net.alloc to try and allocate subnets:
v.net.alloc in=streams_outlet out=streams_alloc nfield=1 ccats=1
However, when I then try to extract the largest subnet with v.extract,
it does not work. That is, I get only 2 subnets, the connecting vector
used in v.patch (cat=0) and the entire stream network (cat=1),
including the disconnected fragments! I thought v.net.alloc was
supposed to allocate connected regions to subnets, yet this is not what
is happening (apparently). What am I doing wrong?
Thanks,
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
