[GRASSLIST:2784] Re: error with command of grass5.7
Markus Neteler neteler at itc.it
Sat Feb 28 18:20:55 EST 2004
On Fri, Feb 27, 2004 at 10:48:30AM +0100, hamdi ines wrote:
> Hello,
> I'm installed GRASS5.7 from the source of grass5.3_exp_17_01_2004
> in my platform redhat8.0 but when i use the command ogr, d.m, or d.vect i get the following error. can you help to resolv all this error:
> >GRASS 5.7.-cvs>d.m
> >GRASS 5.7.-cvs:~ > Error in startup script: child killed: bus error
>     while executing
> >"exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> >"DmPrint::init"
>     (procedure "main" line 30)
>     invoked from within
> >"main $argc $argv"
>     (file "/usr/local/grass57/etc/dm/d.m.tcl" line 785)
> >GRASS 5.7.-cvs:~ > ogr2ogr
> ogr2ogr: relocation error: ogr2ogr: undefined symbol: _ZTV13OGRLinearRing
You may need a fresh OGR/GDAL. Try the 1.2.0 from
http://www.remotesensing.org/gdal/
Markus
