[GRASSLIST:2787] Re: Postgresql and SUSE layout
Jens Oberender grass at troja.net
Sun Feb 29 08:08:06 EST 2004
Hi
> The default installation directories that Postgresql uses differ from
> the ones in which SUSE 9.0 puts the software.  Can someone indicate
> where a discription of the default SUSE set-up for postgresql can be
> found?  If I need remove the SUSE Postgresql 7.3 installation, are there
> any particular elements that are no longer included in the 7.4 release
> that are critical to 7.4 function?
You can have a look at the files included in the package (rpm -ql
postgresql | less)
or look what the specfile is doing (that's in the source rpms on the
second side of the DVD, extract the files with rpm2cpio
postgresql-7.3.4-45.src.rpm | cpio -i)
Ciao,
	Jens
PS: If you have more questions, write mit in PM, as postgresql and SUSE
are a bit offtopic on that list.
