[GRASSLIST:2172] building 5.7 on cygwin
Richard Greenwood rich at greenwoodmap.com
Fri Jan 9 12:40:04 EST 2004
Building 5.7 on cygwin I encounter an error - I can not get datetime to
build. It fails with: undefined reference to `_WinMain at 16' (complete
output below). Any suggestions greatly appreciated.
Rich
gcc -s -L/usr/local/lib -L/lib/mingw -I/usr/include/mingw
-I/usr/include/w32api
-L/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib        \
         OBJ.i686-pc-cygwin/between.o OBJ.i686-pc-cygwin/copy.o
OBJ.i686-pc-cygwin/same.o OBJ.i686-pc-cygwin/diff.o
OBJ.i686-pc-cygwin/error.o OBJ.i686-pc-cygwin
/format.o OBJ.i686-pc-cygwin/incr1.o OBJ.i686-pc-cygwin/incr2.o
OBJ.i686-pc-cygwin/incr3.o OBJ.i686-pc-cygwin/local.o
OBJ.i686-pc-cygwin/misc.o OBJ.i686-pc-cygw
in/change.o OBJ.i686-pc-cygwin/scan.o OBJ.i686-pc-cygwin/sign.o
OBJ.i686-pc-cygwin/type.o OBJ.i686-pc-cygwin/tz1.o
OBJ.i686-pc-cygwin/tz2.o OBJ.i686-pc-cygwin/v
alues.o  -o
/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib/libgrass_d
atetime.
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.1/../../../libcygwin.a(libcmain.o)(.text+0x7
c): undefined reference to `_WinMain at 16'
collect2: ld returned 1 exit status
make[2]: ***
[/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib/libgrass
_datetime.] Error 1
make[2]: Leaving directory `/home/Rich/grass57_exp_2004_01_03/lib/datetime'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/Rich/grass57_exp_2004_01_03/lib'
make: *** [default] Error 1
Richard Greenwood
www.greenwoodmap.com
