[GRASSLIST:2195] Re: d.mon socket problem
Ben Logan ben at wblogan.net
Mon Jan 12 14:31:03 EST 2004
On Mon, Jan 12, 2004 at 11:27:36AM -0600, William K wrote:
> make sure you have the DISPLAY environment var set to :0.0
> also make sure X11 is already running, if you're running GRASS from the
> Terminal instead of an X11 xterm.
> On Jan 12, 2004, at 10:16 AM, David Orme wrote:
> >Hi,
> >I've got grass57 built now - thanks to everyone. When I try and start
> >a graphics monitor i get the following (most recent weekly snapshot,
> >Mac OS 10.2.8):
> >>GRASS
> >>5.7.-cvs:/usr/local/src/grass57_exp_2004_01_10/bin.powerpc-apple-
> >>darwin6.8 > d.mon start=x0
> >>ERROR: Graph_Set: can't open Display
> >>No socket to connect to for monitor <x0>.
> >>Problem selecting x0. Will try once more
David,
I don't know anything about the Mac OS, but my understanding is that
it is very unixish.  If that's true, in addition to William's
suggestions, you might make sure you have permission to write to
wherever GRASS is trying to create the sockets.  For example, on my
Linux box, sockets for user "ben" are created in /tmp/grass-ben.  If
"ben" didn't have write permissions on /tmp, no socket(s) could be
created.
Regards,
Ben
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
OpenPGP Key ID: A1ADD1F0
Fingerprint: E32C 1CF9 C2FE DFC9 BB5C  A24F 57DB 5679 A1AD D1F0
Get it from http://cyclist.wblogan.net/benlogan.gpg
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040112/7fb9a125/attachment.bin
