[GRASSLIST:2208] Re: How to display satellite data correctly?
Wolfgang von Hansen wvhansen at web.de
Wed Jan 14 03:43:42 EST 2004
Kris Nackaerts <knackaerts at gmx.net> schrieb am 13.01.04 22:09:11:
> I had the same problem when trying to visualize hyperspectral images. I
> created a script in R (www.r-project.org) to analyze the histogram
> output files and create a GRASS script automatically to correctly
> rescale the values for visualisation. I could then say like remove the
> 5% tails.
I just wrote a small shell script myself which basically uses r.stats, awk and r.colors. Now everything is looking fine!
> If you are interested in this script, let me know. Otherwise, I also
> used just a PCA transform to get a first impression of what was in the
> images.
For the visualization of multispectral data it normally is sufficient to choose some interesting bands by their wavelength, but I agree with you that PCA is a good preprocessing step for visual inspection of a large number of bands.
Wolfgang
______________________________________________________________________________
Erdbeben im Iran: Zehntausende Kinder brauchen Hilfe. UNICEF hilft den
Kindern - helfen Sie mit! https://www.unicef.de/spe/spe_03.php
