[GRASSLIST:2220] Re: converting GRASS data for trend surface analysis i n R
Roger Bivand Roger.Bivand at nhh.no
Wed Jan 14 13:46:25 EST 2004
> Hello all
> I'm trying to do some trend surface analysis with GRASS data in R, but I
> with some problems:
> 1 - when I get the raster from GRASS, surf.ls() doesn't accept it, since
> its not in x,y,z format:
>> str(isobase)
> List of 1
>  $ isobases.auto: num [1:241266] 771 770 769 768 767 ...
> So, how can I change this to a format that surf.ls() understands?
isobase$isobases.auto is the z argument. You can generate the x by east()
of the object returned by gmeta(), and y by north() of this object. I'm
not sure how well surf.ls() scales to this number of points, though.
> 2 - I'll try several degrees of surfaces, so I'll use surf.ls(), but
> what about residuals? can I get them with residuals()?
Yes, residuals() should work. Again, scaling to this number of points is
an issue. On the other hand, the residuals and fitted values will drop
straight into the GRASS location.
Roger
> thanks in advance
> Carlos Grohmann
>         Carlos Henrique Grohmann - Guano
>     Geologist - MSc Student at IGc-USP - Brazil
>        Linux User #89721  ICQ: 214752832
Roger Bivand
NHH, Breiviksveien 40, N-5045 Bergen, Norway
