[GRASSLIST:2225] RE: Changing Paper Size in ps.map
John Gillette JGillette at rfmd.com
Wed Jan 14 15:45:02 EST 2004
As the man page for ps.select says, there should be a file
in $GISBASE/etc/paint/ps.devices with the name you are
selecting (large printer?). Check this file (it is ascii)
and look at the settings.  You should see something like:
level: 2
page width: 8.5000
page height: 14.0000
Are these setting what you expect?
If not, you can create your own custom page size.
John
-----Original Message-----
From: J. Brian Adams [mailto:brian.adams at fandm.edu]
Sent: Wednesday, January 14, 2004 2:29 PM
To: grass list
Subject: [GRASSLIST:2221] Changing Paper Size in ps.map
I have been trying to create a large scale map (18" x 24") using
ps.map.  I set ps.select to the large printer, but when I run ps.map
and view the postscript file it only shows a quarter of the image.  I
convert the file using ps2pdf then view it in Acrobat Reader.  Acrobat
seems to be stuck on standard US Letter.  However, I get the same
result if I view the ps file directly in Mac's Preview.
I am running grass 5.0.2 on Mac OS X 10.3.
Brian
