[GRASSLIST:2226] RE: Changing Paper Size in ps.map
J. Brian Adams brian.adams at fandm.edu
Wed Jan 14 16:15:56 EST 2004
I had created a new file for the printer by copying one of the others
and then making the changes.  It is
level: 2
page width: 18.0
page height: 24.0
top margin: 0.5
bottom margin: 0.5
left margin: 0.25
right margin: 0.25
resolution: 300
On Jan 14, 2004, at 3:45 PM, John Gillette wrote:
> As the man page for ps.select says, there should be a file
> in $GISBASE/etc/paint/ps.devices with the name you are
> selecting (large printer?). Check this file (it is ascii)
> and look at the settings.  You should see something like:
> level: 2
> page width: 8.5000
> page height: 14.0000
> Are these setting what you expect?
> If not, you can create your own custom page size.
> John
> -----Original Message-----
> From: J. Brian Adams [mailto:brian.adams at fandm.edu]
> Sent: Wednesday, January 14, 2004 2:29 PM
> To: grass list
> Subject: [GRASSLIST:2221] Changing Paper Size in ps.map
> I have been trying to create a large scale map (18" x 24") using
> ps.map.  I set ps.select to the large printer, but when I run ps.map
> and view the postscript file it only shows a quarter of the image.  I
> convert the file using ps2pdf then view it in Acrobat Reader.  Acrobat
> seems to be stuck on standard US Letter.  However, I get the same
> result if I view the ps file directly in Mac's Preview.
> I am running grass 5.0.2 on Mac OS X 10.3.
> Brian
