[GRASSLIST:2248] RE: i.points
Uttam Kumar uttamkumar123 at hotmail.com
Fri Jan 16 02:06:53 EST 2004
It is a good idea to toggle off the points in the "Analyse" option in
i.points, you may still see the marked points which appear red on the map;
those points will not be counted in calculating the RMS error. I think you
have to import those images again and create a new group and subgroup if you
want to start anew in the same location. You can chech it out.
best wishes,
uttam.
>From: "Kirk R. Wythers" <kwythers at umn.edu>
>To: GRASSLIST at baylor.edu
>Subject: [GRASSLIST:2216] i.points
>Date: Wed, 14 Jan 2004 09:20:59 -0600
>How does one delete points in order to just start over? I have already
>toggled the points off in the analyze section, but they still appear in red
>on the map. Is there a way to simply b"blow away" the all points and start
>anew?
>Kirk
_________________________________________________________________
NRI’s, Free Money transfer to India.
http://server1.msn.co.in/msnleads/citibankrca/citibankrca2.asp?type=hottag
Click here.
