[GRASSLIST:2249] Re: How to make mosaic of the raster files?
Helmer Schack-Kirchner Helmer.Schack-Kirchner at bodenkunde.uni-freiburg.de
Fri Jan 16 02:16:08 EST 2004
Zbigniew Perski wrote:
> Hi everybody,
> I have 6 scanned maps which was resampled into one project. The maps
> are  overlapping a bit and the scans includes also parts outside the
> map frame. Unfortunately after resampling to the project the mas are
> not rectangular. I would like cut out unwanted parts and mosaic the
> pieces into one file using r.patch. I have tried r.mask but it is
> masking out map values but not map areas. Is there any method in grass
> how to do it?
> Thanks in advance.
> Regards
> Zbigniew
Use the if(when true, choose A, else choose B) function in r.mapcalc.
With this function you may decide, which map in case of  overlapping you
prefer and you may cut undesired areas. To begin it may be easier, to
build the mosaic step by step with only one r.mapcalc if(a,b,c) (with
only two maps included) function, but it is also possible to nest the
if() function to join all 6 maps in one step.
Best regards,
Helmer
