[GRASSLIST:2257] NVIZ on Cygwin
Richard Greenwood rich at greenwoodmap.com
Fri Jan 16 23:52:40 EST 2004
Glynn et al,
I am trying to get NVIZ (from Grass 5.0.3 source) compiled and working
on Cygwin.  I have a new, clean, minimal Cygwin install and built Grass.
It appears to run, as does tcltkgrass, but nviz generates the error [1]
below. Inspecting my config.log, I see a couple suspicious errors, [2]
and [3] below.
[2] says "ld: cannot find -ltk" and neither can I. Do I need to link tk
to something? And if so, what?
[3] is a list of 427 undefined references. Am I missing a library, or a
link, or something in my path?
There are two shell scripts in /usr/local/lib 'tclConfig.sh' and
'tkConfig.sh' which define numerous shell variables.  Is it possible
that these relate to my problem? Do I need to run these prior to
configure and build?
As always, I apprecite the assistance that I receive from this list.
Best regards,
Rich
=== [1] ====
GRASS:~ > nviz ned_patch
child killed: segmentation violation
    while executing
"exec
/home/Rich/grass/grass-5.0.3/dist.i686-pc-cygwin/etc/nviz2.2/NVWISH2.2 -f
/home/Rich/grass/grass-5.0.3/dist.i686-pc-cygwin/etc/nviz2.2/scripts/nv..."
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scri
pts/nviz2.2_script $argv -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scrip
ts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/home/Rich/grass/grass-5.0.3/dist.i686-pc-cygwin/bin/nviz"
line 16)
=== [2] =====
int main() {
Tk_MainWindow()
; return 0; }
configure:8617: checking for Tk_MainWindow in -ltk
configure:8634: gcc -o conftest -O2    -I/usr/include/ncurses  -s
-L/usr/local/lib -L/usr/X11R6/lib conftest.c -ltk  -ltcl8.3
-L/usr/X11R6/lib  -lSM -lICE -lX11   1>&5
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.1/../../../../i686-pc-cygwin/bin/ld:
cannot find -ltk
collect2: ld returned 1 exit status
=== [3] =====
int main() {
Tk_MainWindow()
; return 0; }
configure:8661: checking for Tk_MainWindow in -ltk8.3
configure:8678: gcc -o conftest -O2    -I/usr/include/ncurses  -s
-L/usr/local/lib -L/usr/X11R6/lib conftest.c -ltk8.3  -ltcl8.3    1>&5
/usr/local/lib/libtk8.3.a(tkWindow.o)(.text+0x138c):tkWindow.c:
undefined reference to `_XDestroyWindow'
/usr/local/lib/libtk8.3.a(tkWindow.o)(.text+0x1404):tkWindow.c:
undefined reference to `_XDestroyIC'
##### another 425 lines of libtk8.3. undefined references follow
Richard Greenwood
www.greenwoodmap.com
