[GRASSLIST:2274] Re: Poor quality PNG file driver output
Mon Jan 19 01:41:51 EST 2004
just to note
> 1) GRASS_monitor    screen capture of the GRASS monitor
24-bit TrueColor image
> 2) png_driver.png     produced by the PNG file driver
256 colour indexed image
> 3) xwdtopnm.pnm     produced by the first step in your xwd script.
> This image is perfect and matches the original GRASS monitor contents.
> So far so good.
[sending 1mb files to everyone on the mailing list isn't the best idea, btw]
> 4) pnmtopng.png     produced by the second step in the xwd script.
> This is the output of pnmtopng with no options specified.  I mentioned
> before that I saw dithering, but I realized that it was the viewer
> that I was using (Preview), not the file itself.  Oddly enough, this
> image looks fine when viewed in apps like Photoshop or
> GaphicConverter.  It looks poor in Preview and in Mail.  Either there
> must be something up with PNG files and OS X's quartz layer, or
> there's something strange with the image.  Either way,  this image
> looks like the GRASS Monitor, so this is the method I'll use.
24-bit Grayscale image
maybe the pnmtopng program is being smart & sees that the image has no
colour and thus creates a smaller grayscale PNG image.
If the 24bit TrueColor .pnm file looks good in "Preview", and the 24bit
GrayScale .png doesn't, I'd say it was a "Preview" issue..
tip:
try setting GRASS_WIDTH= and GRASS_HEIGHT= on the command line to get
rid of those black bands on the side.
> >> It was a two-day ordeal for me to get the gd library compiled and
> >> running on my system.
> > I take it you didn't install gd via fink?
> > http://fink.sourceforge.net/pdb/package.php/gd2
> > 'apt-get install gd2' would have done it....
> I tried this, but there were problems with 10.3 and fink.  Fink still
> tries to install xfree86, even though you have Apple's X11 installed.
> So you have to trick it by installing the Apple X11 sdk and change a
> few other things, bla, bla bla.  Plus there are other errors generated
> during building.  I couldn't verify that I was getting a good install.
I don't know if I'd call that tricking it, but ok. I installed Apple's
X11, X11 SDK, & Developer's Tools before I tried Fink on OSX 10.3.
And then Fink worked the first time.. shrug
> > good luck,
> > Hamish
